Peers fail to connect to each others
I’ve been running netbird with no issue for a couple of months, but last week peers seems to have an hard time connecting one to another, some connect, some don’t (maybe one does connect once then doesn’t connect after that) restarting the peers or the server doesn’t seem to do anything… Does anyone know what culd be causing the issue? THe only thing that i changed (and not lately) was enabling the client auto update on the dashboard.
Peers should connect between each other with no issue.
I’m using selfhosted netbird.
peers 0.73.1
server 0.73.1
dashboard 2.39.0
no.
netbird status -dA
C:\Windows\System32>netbird status -dA
oracle.anon-5hlxK.domain:
NetBird IP: 10.10.10.5
Public key: yt8I2jzT8MLqSJrgITRnc1VyUJHZjQnlhEaGkFj1xgE=
Status: Idle
Connection type: -
Relay server address:
Last connection update: -
Last WireGuard handshake: -
ded2.anon-5hlxK.domain:
NetBird IP: 10.10.10.119
Public key: X9vbyb4NhdoKtEY7JxMKIa8IBpvAGimt5YUbs+dubDM=
Status: Idle
Connection type: -
Networks: 192.168.0.0/24
vm63332.anon-5hlxK.domain:
NetBird IP: 10.10.10.161
Public key: +GsK/9axs3+yYSFRUpiSMXdAkAn1xpD+cyJ9j7DcikI=
Status: Idle
Connection type: -
[INFO] SYSTEM (3be8d9c4-adf1-4038-ba6c-aa1d21825418)
Time: 11 hours, 45 minutes ago
[INFO] SYSTEM (a25f65b9-8758-4d17-8b49-1c0e195f1a22)
Time: 11 hours, 40 minutes ago
[INFO] SYSTEM (dc5260fb-6545-4157-81a2-257b2938b585)
Time: 11 hours, 33 minutes ago
[INFO] SYSTEM (bdf22a6f-780e-4ab8-ae79-ad3057caa767)
Time: 11 hours, 28 minutes ago
[INFO] SYSTEM (b425e79e-c227-4457-b8d1-4fb4e3ec66d1)
Time: 2 hours, 9 minutes ago
[INFO] SYSTEM (11e96776-4db2-4136-a47f-2995b8c13696)
Time: 1 hour, 12 minutes ago
[INFO] SYSTEM (d80a04b0-8f27-45bb-b24a-a834edcc7531)
Message: daemon config changed (source=up_rpc)
Time: 30 minutes, 11 seconds ago
Metadata: source: up_rpc, type: config_changed
[INFO] SYSTEM (ff187866-2305-430b-a5b1-601a5efa0b63)
Time: 29 minutes, 41 seconds ago
[INFO] SYSTEM (c8d9292a-f1ac-4535-9b26-7456934fe57f)
Time: 15 minutes, 21 seconds ago
[INFO] SYSTEM (dbf98806-c4ff-488c-aed5-178e7b45eb40)
Time: 14 minutes, 50 seconds ago
OS: windows/amd64
Daemon version: 0.73.1
CLI version: 0.73.1
Profile: titanet
Management: Connected to https://vpn.anon-55BQH.domain:443
Signal: Connected to https://vpn.anon-55BQH.domain:443
[stun:vpn.anon-55BQH.domain:3478] is Available
[rels://vpn.anon-55BQH.domain:443] is Available via ws
[1.1.1.1:53, 1.0.0.1:53] for [.] is Available
FQDN: diegopc-0-226.anon-5hlxK.domain
NetBird IP: 10.10.10.28/24
Interface type: Userspace
Wireguard port: 51820
Lazy connection: true
Peers count: 0/3 Connected
b68d516d0ccfbbf8c668cdd078489763f74fb4a380b761d7e12bd68b08bbc518/8373e827-c86e-45aa-a10d-f3e90f8c71c0
netbird debug for 1m -AS -U
Uploaded files are automatically deleted after 30 days.
Alternatively, create the file only and attach it here manually:
If applicable, add screenshots to help explain your problem.
fix was disabling lazy connections
Could just be funny timing that you happen to try and connect when they all update, but on the other side. Make sure the dashboard also updates in time, and that any changes to the configs for external stuff (e.g. caddy/nginx/etc) also gets properly updated so you don’t get double trouble when trying to connect and the webserver routing your request incorrectly.
