Peer Network Statistics
User peer connectivity troubleshooting can sometimes be cumbersome
Peer latency metric from the management server would be a helpful metric to have displayed in the peer overview section.
Pinging the user peer from the management server, pinging the management server from the user peer, etc.
None
