Hey,
not sure if it might be possible already. What I am looking into is a way to lt the client select an optional network which is not checked by default. Usually I only do split tunneling, so only traffic which needs to go to the specific hosts or network will be over netbird.
But sometimes you just want to use it as a type of VPN to ensure everything goes over the netbird line. But as said, not always.
Anybody have a IDea how to achieve this easy that even non experienced users can quickly toggle “full route vpn” on/off ?
I thought about adding a endpoint for this, but as soon as I put it in the matching user group it is toggled on by default. Works fine but I would love to see it set as optional (default disabled) netowork to choose in the gui.
Thanks for thoughts
