When I select the defined exitnodes to be routed through their IP address, no website or services work. However, at the same time I am able to successfully ping all the websites in my Terminal. When connected, I can successfully ping and open other local ips available in my network.
Connect to the network, then select an exit node. Then try openning websites such as google!
Obviously, the websites should open after connecting to an exit node.
no
Managementv0.66.1 Dashboardv2.33.0
Yes, Mullvad but obviously disabled.
I am not sure how I should do this. The given command did not work. Shall I call a docker first and then run this command. I am newbie, your help here would he appreciated.
