No longer admin after IdP Migration
After performing the migration as detailed in Migration Guide: External IdP to Embedded IdP - NetBird Docs I am no longer admin and can therefor not access all of my previous peers.
  1. Follow migration guide
  2. Use Authentik
  3. Log in again
  4. See that you are no longer admin
Should still be admin and if not at least re-admin again.
No, using selfhosted.
v0.77.1
None
Not relevant issue does not concern client.
None
Issue concerns dashboard.
Is there a way to promote my user to admin again, or do I have to go into the db and hack sth together? Thanks in advance!
Indeed this was the case the migrated account seems to have been created instead of modifying the old one. So I did some UPDATE ops and set the role to `owner!
Oh and also don’t forget to dethrown the old user back to role='user' to be able to delete it.
