netbird v0.81.0-canary.pr-7662.1 released
- [management] Speed up test store setup and summarize the unit test run by @mlsmaycon in https://github.com/netbirdio/netbird/pull/7518
- [management] Refuse to pin an agent network gateway onto another account’s host by @mlsmaycon in [management] Refuse to pin an agent network gateway onto another account's host by mlsmaycon · Pull Request #7519 · netbirdio/netbird · GitHub
- [management] Validate the proxy cluster an agent network bootstraps onto by @mlsmaycon in [management] Validate the proxy cluster an agent network bootstraps onto by mlsmaycon · Pull Request #7402 · netbirdio/netbird · GitHub
- [management] Point the agent-config e2e providers at the mock upstream by @mlsmaycon in [management] Point the agent-config e2e providers at the mock upstream by mlsmaycon · Pull Request #7542 · netbirdio/netbird · GitHub
- [client] Stage install script downloads in a private temp directory by @riccardomanfrin in [client] Stage install script downloads in a private temp directory by riccardomanfrin · Pull Request #7534 · netbirdio/netbird · GitHub
- [client] Read the session deadline under the status read lock by @pappz in [client] Read the session deadline under the status read lock by pappz · Pull Request #7550 · netbirdio/netbird · GitHub
- [client] Enforce HTTPS on install script downloads by @riccardomanfrin in [client] Enforce HTTPS on install script downloads by riccardomanfrin · Pull Request #7545 · netbirdio/netbird · GitHub
- [misc] Load AGENTS.md every session and refuse attribution trailers by @mlsmaycon in [misc] Load AGENTS.md every session and refuse attribution trailers by mlsmaycon · Pull Request #7544 · netbirdio/netbird · GitHub
- [client] Fix - Add RPM metadata required for Red Hat software certification by @braginini in [client] Fix - Add RPM metadata required for Red Hat software certification by braginini · Pull Request #7562 · netbirdio/netbird · GitHub
- [management] Read X-Real-IP when extracting the peer connection IP by @bcmmbaga in [management] Read X-Real-IP when extracting the peer connection IP by bcmmbaga · Pull Request #7561 · netbirdio/netbird · GitHub
- [management] Handle empty trusted peer by @bcmmbaga in [management] Handle empty trusted peer by bcmmbaga · Pull Request #7589 · netbirdio/netbird · GitHub
- [proxy] Close the client connection on private service denials by @mlsmaycon in [proxy] Close the client connection on private service denials by mlsmaycon · Pull Request #7590 · netbirdio/netbird · GitHub
- [management] Name the account owner in the pending approval error by @heisbrot in [management] Name the account owner in the pending approval error by heisbrot · Pull Request #7533 · netbirdio/netbird · GitHub
- [proxy] add proxy rate limiter by @pascal-fischer in [proxy] add proxy rate limiter by pascal-fischer · Pull Request #7568 · netbirdio/netbird · GitHub
- [management] Add proxy credentials limiter on management by @pascal-fischer in [management] Add proxy credentials limiter on management by pascal-fischer · Pull Request #7569 · netbirdio/netbird · GitHub
- [client] Fix peers not being notified when the relay connection drops by @pappz in https://github.com/netbirdio/netbird/pull/7490
- [management] fix group resource validation by @pascal-fischer in [management] fix group resource validation by pascal-fischer · Pull Request #7608 · netbirdio/netbird · GitHub
- [client] Remove the empty GPO DNS policy store on Windows teardown by @lixmal in [client] Remove the empty GPO DNS policy store on Windows teardown by lixmal · Pull Request #7563 · netbirdio/netbird · GitHub
- [management] add store support to filter by public id by @pascal-fischer in [management] add store support to filter by public id by pascal-fischer · Pull Request #7208 · netbirdio/netbird · GitHub
- [client,management] Skip route firewall rule computation when no firewall by @riccardomanfrin in [client,management] Skip route firewall rule computation when no firewall by riccardomanfrin · Pull Request #7624 · netbirdio/netbird · GitHub
- [management] record proxy version on connect by @pascal-fischer in [management] record proxy version on connect by pascal-fischer · Pull Request #7630 · netbirdio/netbird · GitHub
- [management,signal,proxy] add pyroscope profiling by @pascal-fischer in [management,signal,proxy] add pyroscope profiling by pascal-fischer · Pull Request #7536 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.79.0-rc.1...v0.81.0-canary.pr-7662.1 · netbirdio/netbird · GitHub
