Release Notes for v0.75.1
Agent Network
Added prompt cache token and cost accounting to Agent Network usage.
[management, proxy] Add prompt-cache token and cost accounting to agent network usage by mlsmaycon · Pull Request #6900 · netbirdio/netbird · GitHub -
Added support for Claude Opus 5.
[management, proxy] Add Claude opus 5 by braginini · Pull Request #6895 · netbirdio/netbird · GitHub -
Scoped Agent Network model allowlists per policy, group, and provider.
[management, proxy] scope agent-network model allowlist per policy/group and provider by mlsmaycon · Pull Request #6905 · netbirdio/netbird · GitHub
Client Improvements
Reconcile routed AllowedIPs when a lazy connection becomes idle.
[client] Reconcile routed allowed IPs when a lazy connection goes idle by riccardomanfrin · Pull Request #6863 · netbirdio/netbird · GitHub -
Fetch FreeBSD port files from the GitHub mirror instead of cgit.
[client] Fetch FreeBSD port files from GitHub mirror instead of cgit by pappz · Pull Request #6880 · netbirdio/netbird · GitHub -
Restored the missing
backup.Resetbehavior.
[client] Restores lost backup.Reset from #4935 by riccardomanfrin · Pull Request #6883 · netbirdio/netbird · GitHub -
Made
Test_ConnectPeersdeterministic under Docker/eBPF kernel and Darwin CI.
[client] Make Test_ConnectPeers deterministic under Docker/eBPF kernel / Darwin CI by riccardomanfrin · Pull Request #6884 · netbirdio/netbird · GitHub -
Export agent version information for iOS.
[client] Export agent version info for iOS by pappz · Pull Request #6918 · netbirdio/netbird · GitHub -
Use platform-specific installer URLs for manual update downloads.
[client] Use platform installer URL for manual update downloads by pappz · Pull Request #6922 · netbirdio/netbird · GitHub -
Exit the GUI immediately when the Windows session ends.
[client] Exit GUI immediately on Windows session end by pappz · Pull Request #6878 · netbirdio/netbird · GitHub -
Fixed stale routing peers after removing overlapping-prefix networks.
[client] fix stale routing peer on overlapping-prefix network removal by riccardomanfrin · Pull Request #6799 · netbirdio/netbird · GitHub -
Added
ReapplyMatchingsupport to the dedicatedAllowedIPsRefCounter.
[client] fix build: add ReapplyMatching to dedicated AllowedIPsRefCounter by riccardomanfrin · Pull Request #6935 · netbirdio/netbird · GitHub
Infrastructure & Miscellaneous
- Restored the
rootless-latestDocker image tag.
[misc] Restore the rootless-latest docker tag by lixmal · Pull Request #6914 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.75.0...v0.75.1 · netbirdio/netbird · GitHub
