I accidentally discovered a problem with the self-hosted netbird server. From one day to the next I no longer have access to the web interface and all connections including the reverse proxy. I thought something must have crashed.
So I started restore backups. Everything didn’t work. The problem was that netbird.io was entered on a block list in Adguard.
I use my own domain for my installation. This means that even if I have my own server and the domain netbird.io cannot be reached, the entire service is unusable. I have now added this domain to the whitelist.
You can then use Netbird again. That can’t be right, can it?
