Hi Guys and Girls,
I’m from Germany and new here. I hope you can help me with my current (and maybe future) Problems
Disclamer:
I use ChatGPT to make the text better readable
I am currently setting up a self-hosted NetBird environment.
Besides the NetBird management server, I want to run a dedicated exit node and several additional nodes that connect to conventional commercial VPN providers and my phone (through regular WireGuard) on the same VPS.
In addition to my own exit, I would like to have separate nodes connected to different commercial VPN providers, so that I can selectively route traffic from specific devices through a particular VPN provider when needed.
One of the main questions I am trying to solve is how to structure this setup cleanly.
I tried to set up a second Docker Stack beside the Management Stack, but if I start the Docker with the Node, it kills my Server.
I tried to troubleshoot this with ChatGPT, and my conclusion is that it is not possible to run these Docker stacks side by side. So, on my VPS, the only way seems to be to use LXC instead.
But I’m unsure whether the Management Stack will work properly inside the LXC.
So my question is: Has anyone here done the same or something similar, and is it really as easy as “just do it inside an LXC”, or should I expect problems with the Management Stack?
Try to run a Client Docker beside the Management Docker Stack
See above (run some Nodes beside the Management-Server)
No, I host it by my own on a VPS
netbird version = 0.79
Debug (output)
The following is a summary from ChatGPT after the Troubleshooting I tried with the help of LLM:
The container runs with:
network_mode: host -
NET_ADMIN,SYS_ADMIN,SYS_RESOURCE -
/dev/net/tun -
NetBird
0.79.0
The VPS itself is secured with iptables-nft and has IPv4/IPv6 forwarding enabled.
During the first start, shortly before the VPS became unreachable, the following was logged:
Routing setup complete
creating an nftables firewall manager
After that, the entire VPS became unreachable.
After restoring a snapshot, I started the container again, this time with:
NB_DISABLE_FIREWALL=true
This is also confirmed by NetBird:
firewall is disabled
Nevertheless, the VPS becomes unreachable again when the container starts.
This time, the following additionally appears beforehand:
Error setting up sysctl:
write sysctl net.ipv4.conf.all.src_valid_mark:
open /proc/sys/net/ipv4/conf/all/src_valid_mark:
read-only file system
NetBird then continues starting:
Netbird engine started
Interface monitor: watching wt0
Connected
My suspicion at this point is therefore that the NetBird firewall is not primarily causing the problem, but rather that the exit node, through network_mode: host, is making routing/network changes directly to the network stack of the VPS.
nothing to add yet
- Disabled other VPN software
- Checked firewall settings
