Ha database Netbird
Hi, i have setup Netbird free like this and is it functionnal
one vm traefik + ha proxy
two vm netbird server (signal, management, dashboard + client for routing with router)
two databases servers pgsql in active passive
all is fine but if i shut the first server netbird, i don’t have choice with local login for admin and entra id for users…
seems to be a local cache of info on the first node ?
someone test this type of install with netbird ?
I tested a similar setup with two v0.82.0 server instances in a Debian VM. With a shared management database but separate local authentication stores, switching to the second instance lost the Microsoft login choice, and that instance had no copy of the admin password. Repeating the test with a shared PostgreSQL authentication store preserved the login choice. I used a dummy Microsoft connector, so this didn’t test a complete Entra login or your load-balancer setup.
Could you check whether both nodes also share server.authStore? Configuring server.store for PostgreSQL leaves authentication data in a separate local idp.db unless you configure and migrate that too. The auth-store migration guide covers this.
I couldn’t find an open Discussion matching this symptom. Please open a GitHub Discussion with your server and dashboard versions, sanitized store and authStore settings from both nodes, and logs captured while stopping the first node. Please also describe exactly what appears on the login page afterward and whether both NetBird servers normally run simultaneously.
That last detail matters: supported active-active Management and Signal HA requires Enterprise and additional shared services; PostgreSQL replication alone doesn’t provide it.
