Can't set NB_ENABLE_LOCAL_FORWARDING=true
I’m trying Reach Services on the Routing Peer but I get the following error:
C:\Windows\System32>netbird service reconfigure --service-env NB_ENABLE_LOCAL_FORWARDING=true
Stopping NetBird service...
Removing existing service configuration...
Installing service with new configuration...
Error: install service with new config: failed setting env var registry key, err = Illegal operation attempted on a registry key that has been marked for deletion.
Forgot to mention the computer is Windows 11.
After removing the Netbird client, rebooting and installing the v0.78.2 Netbird client, I was able to run the netbird service reconfigure --service-env NB_ENABLE_LOCAL_FORWARDING=true command without error.
I’m not 100% sure, but I think I had v0.78.1 installed when I was getting the error.
