I’ve created a resource 10.82.4.0/24 for a remote network sitting behind an OPNsense firewall, and I was checking to see if an IP in that block was currently in use, when I realized that all IPs are replying. Tested from two different clients (Win/Mac)
- Go to Command Prompt/Terminal
- Ping any address within the network block
- See output
╰─$ ping 10.82.4.6
PING 10.82.4.6 (10.82.4.6): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
64 bytes from 10.82.4.6: icmp_seq=0 ttl=64 time=5048.990 ms
Request timeout for icmp_seq 6
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
Request timeout for icmp_seq 9
64 bytes from 10.82.4.6: icmp_seq=1 ttl=64 time=9082.407 ms
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
64 bytes from 10.82.4.6: icmp_seq=2 ttl=64 time=13089.336 ms
Request timeout for icmp_seq 16
Request timeout for icmp_seq 17
Request timeout for icmp_seq 18
Request timeout for icmp_seq 19
64 bytes from 10.82.4.6: icmp_seq=3 ttl=64 time=17096.447 ms
Request timeout for icmp_seq 21
Request timeout for icmp_seq 22
Request timeout for icmp_seq 23
Request timeout for icmp_seq 24
64 bytes from 10.82.4.6: icmp_seq=4 ttl=64 time=21096.514 ms
64 bytes from 10.82.4.6: icmp_seq=5 ttl=64 time=20093.983 ms
64 bytes from 10.82.4.6: icmp_seq=6 ttl=64 time=19099.429 ms
64 bytes from 10.82.4.6: icmp_seq=7 ttl=64 time=18095.092 ms
64 bytes from 10.82.4.6: icmp_seq=8 ttl=64 time=17090.037 ms
64 bytes from 10.82.4.6: icmp_seq=9 ttl=64 time=16084.702 ms
64 bytes from 10.82.4.6: icmp_seq=10 ttl=64 time=15081.961 ms
64 bytes from 10.82.4.6: icmp_seq=11 ttl=64 time=14077.384 ms
64 bytes from 10.82.4.6: icmp_seq=12 ttl=64 time=13076.345 ms
64 bytes from 10.82.4.6: icmp_seq=13 ttl=64 time=12071.886 ms
64 bytes from 10.82.4.6: icmp_seq=14 ttl=64 time=11066.650 ms
64 bytes from 10.82.4.6: icmp_seq=15 ttl=64 time=10064.457 ms
64 bytes from 10.82.4.6: icmp_seq=16 ttl=64 time=9059.240 ms
64 bytes from 10.82.4.6: icmp_seq=17 ttl=64 time=8054.400 ms
64 bytes from 10.82.4.6: icmp_seq=18 ttl=64 time=7049.042 ms
64 bytes from 10.82.4.6: icmp_seq=19 ttl=64 time=6047.654 ms
64 bytes from 10.82.4.6: icmp_seq=20 ttl=64 time=5045.870 ms
64 bytes from 10.82.4.6: icmp_seq=21 ttl=64 time=4040.569 ms
64 bytes from 10.82.4.6: icmp_seq=22 ttl=64 time=3038.799 ms
64 bytes from 10.82.4.6: icmp_seq=23 ttl=64 time=2034.966 ms
64 bytes from 10.82.4.6: icmp_seq=24 ttl=64 time=1029.736 ms
64 bytes from 10.82.4.6: icmp_seq=25 ttl=64 time=45.700 ms
64 bytes from 10.82.4.6: icmp_seq=26 ttl=64 time=22.710 ms
64 bytes from 10.82.4.6: icmp_seq=27 ttl=64 time=26.229 ms
When pinging an active IP, the device replies immediately.
─$ ping 10.82.4.2
PING 10.82.4.2 (10.82.4.2): 56 data bytes
64 bytes from 10.82.4.2: icmp_seq=0 ttl=64 time=26.997 ms
64 bytes from 10.82.4.2: icmp_seq=1 ttl=64 time=25.828 ms
64 bytes from 10.82.4.2: icmp_seq=2 ttl=64 time=24.639 ms
64 bytes from 10.82.4.2: icmp_seq=3 ttl=64 time=31.134 ms
64 bytes from 10.82.4.2: icmp_seq=4 ttl=64 time=25.853 ms
I expect only the firewall and one other device in the network to reply to ping.
Self-hosted.
Tested on Windows and MacOS client. Routing peer is OPNsense.
OPNsense 25.7.9-amd64
Daemon version: 0.59.8
CLI version: 0.59.8
Windows 11
OS: windows/amd64
Daemon version: 0.60.7
CLI version: 0.60.7
MacOS
OS: darwin/arm64
CLI version: 0.60.7
OpenVPN client is installed on OPNsense firewall, but I’ve tested it while connected and disconnected. No change. No other VPN client on clients.
netbird status -dA
─$ netbird status -dA
fw-clc.nb.anon-LxI9t.domain:
NetBird IP: 10.15.1.92
Public key: DJ+F7zb1D99p3iTgQUDisFrf8uC5uHHgnCKg88h3rhw=
Status: Idle
Connection type: -
Relay server address:
Last connection update: -
Last WireGuard handshake: -
Networks: 10.34.0.1/32, 10.34.4.0/24, 10.34.5.0/24
fw-02-1-134.nb.anon-LxI9t.domain:
NetBird IP: 10.15.1.134
Public key: r0QSP2I0hLi9TD3GNcNhpevWjZG78f2WTjVzyS8pkTo=
Status: Idle
Connection type: -
fw-01.nb.anon-LxI9t.domain:
NetBird IP: 10.15.1.164
Public key: ZwqRfsjxso1NydcKg7S2sFfM2rLJc5CG+v6LZe2yyz4=
Status: Idle
Connection type: -
Networks: 10.25.0.1/32, 10.25.1.0/24, 10.25.2.0/24, 10.25.3.0/24, 10.25.4.0/24, 10.25.5.0/24, 10.27.0.1/32, 10.27.1.0/24, 10.27.2.0/24, 10.27.4.0/24, 10.27.5.0/24, 10.33.0.1/32, 10.33.1.0/24, 10.33.2.0/24, 10.33.3.0/24, 10.33.3.5/32, 10.33.4.0/24, 10.33.5.0/24
fw-01-1-217.nb.anon-LxI9t.domain:
NetBird IP: 10.15.1.217
Public key: eClQGCQMGtPDkW0Jj/LZLYDKSAmCSu2h9sSj/KhFchM=
Connection type: P2P
ICE candidate (Local/Remote): host/host
ICE candidate endpoints (Local/Remote): 192.168.8.107:53403/198.51.100.0:51820
Relay server address: rel://netbird.anon-LxI9t.domain:33080
Last connection update: 23 minutes, 58 seconds ago
Last WireGuard handshake: 1 minute, 49 seconds ago
Transfer status (received/sent) 50.0 KiB/30.1 KiB
Networks: 10.19.0.1/32, 10.19.1.0/24, 10.19.2.0/24, 10.19.4.0/24, 10.19.5.0/24, 10.20.0.0/28, 10.20.0.4/32, 10.20.0.5/32, 10.20.0.6/32, 10.20.1.0/24, 10.20.1.198/32, 10.20.14.0/24, 10.20.15.0/24, 10.20.16.0/24, 10.20.2.0/24, 10.20.3.0/24, 10.20.3.2/32, 10.20.3.34/32, 10.20.4.0/24, 10.20.5.0/24, 10.20.8.0/24, 10.21.0.1/32, 10.21.1.0/24, 10.21.2.0/24, 10.21.3.0/24, 10.21.4.0/24, 10.21.5.0/24, 10.22.1.0/24, 10.22.2.0/24, 10.22.4.0/24, 10.22.5.0/24, 10.23.0.1/32, 10.23.1.0/24, 10.23.2.0/24, 10.23.3.0/24, 10.23.4.0/24, 10.23.5.0/24, brick.anon-WPMFg.domain, creemore.anon-WPMFg.domain, epad.md.bonnyville.anon-Mm4oy.domain, lakeland.anon-WPMFg.domain, nas-sr-r1u30.mo.anon-LxI9t.domain, nwt.anon-WPMFg.domain, partake.anon-WPMFg.domain, postmark.anon-WPMFg.domain, propeller.anon-WPMFg.domain
Latency: 17.79775ms
fw-1-242.nb.anon-LxI9t.domain:
NetBird IP: 10.15.1.242
Public key: jeG8b0PMtAU+K6eWQlVMd0Z9pXeE+0cobESi+da5nns=
ICE candidate (Local/Remote): srflx/host
ICE candidate endpoints (Local/Remote): 198.51.100.1:53403/198.51.100.2:51820
Last connection update: 23 minutes, 57 seconds ago
Last WireGuard handshake: 1 minute, 11 seconds ago
Transfer status (received/sent) 2.6 MiB/344.6 KiB
Networks: 10.82.0.1/32, 10.82.4.0/24
Latency: 22.416958ms
[WARNING] DNS (4a3a40a7-0b87-42c9-9465-619b36d70c88)
Message: All upstream servers failed (probe failed)
Time: 24 minutes, 45 seconds ago
Metadata: upstreams: 10.20.3.2:53, 10.20.3.34:53
[INFO] SYSTEM (51b9c390-036f-4767-9652-972e30bf8293)
[WARNING] DNS (9fb33e6b-c355-4f10-9166-7bc1995d863d)
Time: 23 minutes, 59 seconds ago
[WARNING] DNS (2352d301-c97e-4a9f-a0e2-6f2727ddc6ee)
[WARNING] DNS (530c79bf-9f15-43b3-9c4a-2135f4c607db)
Time: 23 minutes, 58 seconds ago
[WARNING] DNS (ed1bdfff-96d8-4e65-a924-5056d524dd37)
[WARNING] DNS (aa358ce7-1a35-4106-91de-be652929feaa)
[INFO] SYSTEM (28cc3b65-3bc5-4acc-8e1c-9a8faa67d684)
[INFO] SYSTEM (9fe6df97-825f-44ed-957a-c45007f4a15e)
Time: 10 minutes, 31 seconds ago
[INFO] SYSTEM (7dc5d707-7f4c-4810-a5b1-1634e09f32f5)
Time: 10 minutes, 27 seconds ago
OS: darwin/arm64
CLI version: 0.60.7
Profile: MDofBonnyville
Management: Connected to https://netbird.anon-LxI9t.domain:33073
Signal: Connected to http://netbird.anon-LxI9t.domain:10000
[stun:netbird.anon-LxI9t.domain:3478] is Available
[turn:netbird.anon-LxI9t.domain:3478?transport=udp] is Available
[rel://netbird.anon-LxI9t.domain:33080] is Available
[10.20.3.2:53, 10.20.3.34:53] for [md.bonnyville.anon-Mm4oy.domain, anon-LxI9t.domain, anon-WPMFg.domain, anon-9nLrc.domain, anon-tZvzD.domain] is Available
FQDN: als-mbp.nb.anon-LxI9t.domain
NetBird IP: 10.15.1.113/24
Interface type: Userspace
Lazy connection: true
Forwarding rules: 0
Peers count: 2/5 Connected
netbird debug for 1m -AS -U
Uploaded files are automatically deleted after 30 days.
Alternatively, create the file only and attach it here manually:
I ran the command on the routing peer, but can’t seem to upload it here as it only allows images…
If applicable, add screenshots to help explain your problem.
Partial ARP table of IPs in the same block (obfuscated). Ran on routing peer I’m trying to reach (OPNsense)
? (10.82.4.247) at XX:50:c2:XX:90:15 on bridge0 expires in 1186 seconds [bridge]
? (10.82.4.1) at XX:9c:fc:XX:d2:3c on bridge0 permanent [bridge]
? (10.82.4.2) at XX:1b:f8:XX:8e:a6 on bridge0 expires in 812 seconds [bridge]
- Disabled other VPN software
- Checked firewall settings
